Unfortunately, a Detroit on a 2012-up will not work.
It does work. I drive mine daily with no lights and rarely get a limp mode with no lights where it decides that shifting is overrated. A quick cycle of the ignition and all is well. Is it for everyone? NO but if you know how a locker works and have driven with auto lockers in the past you can still run an auto locker with issues. The issue comes when you try to break a tire loose and traction control cant stop it it throws a wheel speed doesnt match trans output speed fault and causes limp mode.
If your alignment is off or you have a bent link or anything to make the rear axle slightly askew so the locker engages when it shouldn't it will throw limp mode. I'm working on a way to desensitize the system so traction control still works but isn't as sensitive.
The fact that you have to desensitize the system so you can drive it normally speaks volumes as to why a Detroit isn't a good locker for a jeep.
Being that it does not retain all factory features and drivability, I would say it doesn't "work".
Except for it being a dead reliable locker that doesn't require wiring or air compressors or any outside input. It's not for everyone but it's been my locker of choice now for 15 years
I'm over a year into owning mine and have had 4 limp mode instances to date including the one driving out of my shop after installing and not programming the correct gear ratios. I don't know how bad some of the issues are but as long as the speed sensors at each wheel have the correct difference in voltage based on steering input and speed you shouldn't get a fault. That leads me to think the locker isn't so much the culprit as the supporting mods are. Interesting that some go limp mode just driving straight where others are first turn and others have very few issues.
