Dstrick88
I have a 2008 Jeep Wrangler unlimited Sarah 4x4 automatic. 3” lift 35” tires.
Current issue I’m having: the Jeep drives fine in 2 high with no issues. When I shift it into 4x4 high or low, the car rolls about a foot then the locks up. Locking up meaning the front tires drag and will not drive, put it in reverse and it rolls about a foot back and locks up again. I’ve check and changed the oil in the front and rear diffs, no signs of damage. Hasn’t been re-geared. I replaced the lower transfer case cable bushing and the one on the gear selector is fine. I’m at a loss as to what’s causing this issue, I’m going to change the fluid in the transfer case to see if this helps. Any ideas?
Does the transfer case cable need adjusted when the vehicle is lifted?
