TormentedCrawler
Hi all. Has anyone ever ran this combo. Recently purchased the rear bumper fascia and called offroad evolution. They mention it slips over the AntiRock bracket but I don't see how the physically possible.
If it were me, I would NOT run an Antirock. They squeak like a banshee and they WILL LIMIT your flex.
I've been running it for a while already and so far so good. Haven't had any issues with squeak
Nevada. Did you run the Currie bracket on top of the fascia
Here is what my setup looks like:
But it is not flush because I believe that ORE did this to make room for the rear bump stops. Nonetheless, they still rub a little bit on the left side:
I have found that the Curries keep the rig quite level, but believe that this is at the cost of flex.
The squeeking for my setup was mostly due to the sway bar links. A couple of drops of gun oil ("CLP") solved that really well. I have not greased the bushings yet, so still some squeeking left there.
That's exactly what I was thinking. View attachment 221988View attachment 221989
If I notch the bumper will 2 bolts on each side be sufficient enough.
On the fascia, I don't see why not?
I would hate to cut it though. I'll see if I can mount the brackets to the outside
All u have to do is cut a 1/4 inch off the currie antirock brackets where the torsion bar slipps thru.
so I could gain the extra 1/4" to protrude outwards?
