Mkp08
I won this kit in Moab At the jeep Saffari its brand new never been used 3 inch lift from Fabtech, I have a Evo enforcer lift on my jeep so I have no need for it. This system utilizes the factory coil springs with 3" steel coil spacers. With the vast array of cab and motor combinations found in the JK, utilization of the factory coil springs with this system ensures that the vehicle will receive a full 3" of lift to clear 35/1250R17 tires. This system includes a replacement Pitman Arm, front and rear Trac Bar relocation brackets, Sway Bar Links, front and rear Bump Stop mounts, gusset kit, and more. Proper front end alignment is insured with this system due to the included adjustable alignment cams. Also included is a front driveshaft boot clamp kit to allow additional clearance between the front driveshaft and transmission during full suspension articulation. This system capitalizes on Jeep's very capable factory suspension design with the benefit of additional wheelwell clearance to run 35" tall tires for all around on and offroad performance. Fits all JK's 2007-2015. Im asking 850.00 shipping not included im located in Utah.
