Jeep best top trektop NXsoft top
Bpaige88
I have a 4 door Jeep Wrangler rubicon and I just put a soft top on the jeep. I am having an issue where the back bracket where the left rear window sits isn't lining up. The passenger side does but the drives doesn't. The rear door is supposed to keep the window in place but there is a gap. Anyone have this issue?
Are you referring to the driver side rear door surround? And is the gap on the side or bottom picture may help as well..
If it is on the surround, try unzipping the zippers half way and tucking the window around the surround then closing the door and zipping back up. If I understand the issue correctly
I agree I think this is the issue as well... Also keep your sunrider top flipped back till you have it all installed in the surround lip and rail edge than close your front sunrider up
I have the same issue where it doesn't quite fit all the way in one of the doors. I was hoping it being in the sun would stretch it a bit more but no luck. I'm going to try unzipping it halfway and fixing it with the front flipped back
I had to work at mine a few times, try this. Unzip both side of the rear window all the way up to about 3- 4 inches from the top. Pull all the lower tuck tabs out of the lower portion of the side window that is giving you trouble. Then you will have plenty of slack to tuck the window in the door track. Once its tucked, zip that same side zipper down about half way or enough where the lower windows tabs have to snap into place. Work your way around the lower tabs and zippers down.
The main thing is get that window in its door track before you zip down the rear and before you pop the lower tabs in.
