Okay so I know things are going to rub and or get scratched, but should this happen?
And should I be worried?
andrew -
So would new rear uppers allow me to adjust that or do I need rear lowers as well?
andrew -
Is this only happening on one side? If so maybe adjusting the track bar a lil would fix it?
Oh, you don't have either of them. Well, if that's the case, the position of your axle front to back may be okay. Still, adjustable upper and lower arms would help you to address this if you really wanted to.
No I only have the ENFORCER kit as of now. I did notice though that the EVO trackbar bracket is different from what I have. Maybe replacing that might give me more clearance between the bracket and the shock.
View attachment 19056 mine
View attachment 19057 EVO
LOOKS LIKE IT IS TIME TO UPGRADE/UPDATE...
Ah!! Well that would explain everything!! :cheesy:
Yeah, all this time I had assumed you were running an EVO bracket but clearly, what you have does not provide the clearance needed. :crazyeyes:
So I took a ride to ORE this morning and talked to Jake and I should be good trimming the existing bracket down a bit to allow for more clearance. I figured that could be done, just wanted a professional second opinion.
:beer:
