holy_crap
OK, so I just finished installing my Superwinch Tigershark 11500 winch. To spool the line in for the first time, I planned to use the Jeep's rolling resistance from the bottom of my very slight incline driveway. So I placed my Jeep at the bottom of my driveway, ran the line towards a tree, had to use a snatch block because the distance was too short, and brought it back to the Jeep and hooked it. Everything was going fine, my neighbors were giving me funny looks, but I felt like a bad ass as I carefully level wound the rope into the drum. Once I got it all in, I went back to the cab to go put the Jeep in park and WHAT!!! it was in park the whole time :doh: I look behind the Jeep and I see a set of skid marks going towards the tree like someone slammed their brakes right before plowing into my yard and tree.
My question for you guys, it is recommended to apply about 500 lbs of tension, which I was hoping to simulate by pulling my Jeep up the driveway in neutral. Since I pulled it in park, I probably exceeded the 500 lbs by a lot. Is this a bad thing to leave it like that? Or will I need to unwind it and pull the Jeep up in neutral as intended. I'm thinking if I remember my physics correctly, that by using the snatch block I effectively reduced the tension at the drum by half, is this still too much? I have no idea what the rolling, or rather dragging resistance of the JKU is.
