Too Much Lift!!!
Hey, my first post!
This forum is great... much more technical/useful than some of the other ones out there! I love the writeups too.
So, I installed the Rancho 2" sport lift on my 2013 2dr 6-speed JK and got a little more lift than I bargained for. According to the following diagram, I am sitting at just over a confirmed 3" of lift from stock.
I measured my castor angle to be ~5 degrees.
My front driveshaft does not appear to be at a very steep angle, and it is resting ~1.125" above the exhaust pipe.
The rear driveshaft appears to be at a much steeper angle, though I only added the .75" spacer so it should be only .75" of lift
After installing the lift, I did not need to recenter the steering wheel. I drives just about the same as stock, although I seem to feel a slight hesitation when starting from a dead stop. I mean SLIGHT and it may be my imagination but the transmission feels just a tiny bit more lurchy than before (it always felt a little like this and it may not even be a difference, but you always notice things more when you're looking!).
Hey, my first post!
