TomJK
Hey all
I need some help. I'm not much good on transmissions, so of course that's my newest noise...
I've heard the first noise for quite a while (3 years or so), but assumed it was a "normal jeep noise". However, I decided to get to the bottom of it, and do some testing. I put the transfer case in N, to listen to it while not driving. As you can hear, the noise occurs while the clutch is engaged, and disappears while It's disengaged. This lead me to think input shaft bearing. However, while doing this test, I decided to shift through the gears, and that's when I noticed the additional noises while in gear. What could be causing that noise?
The gear noises seem to start in 2nd, and get louder in each higher gear. Reverse gear (not in the video) sounds similar to 5 or 6.
NB - the sounds while in gear are much louder in the video, than in real life. For whatever reason, my phone amplified the sound. In real life, they are clearly noticeable while parked and going through the gears, but while driving they are drowned out by road noise - I'd never heard them until this testing.
I have a 2008 Wrangler JKUX with just over 90k miles. I don't really notice any performance issues, though sometimes there's a hard knock feeling and sound when a new gear engages. Also, I've had an unidentified rattle sound when accelerating, similar to the underspeed rattle sound (though I'm not underspeeding). I'm not sure if that's related, it's been around longer than I remember these sounds, and I've been thinking it's in the rear differential, but who knows.
Maybe I'll try holy water....
https://youtu.be/jegL0ge4F3M
