Info on a lifts
grimlin
So I’m just curious on what size lift I can do with out changing driveshafts on a 2013 Jeep wrangler jk 4 door
As mentioned, on a 4-door, anything over 2.5" of actual lift will put your front drive shaft cv boot at the transfer case in a constant state of pinch. This WILL cause it to fail sooner than later. That said, even with a smaller lift, if you do a lot of big flexing on the trail, you will need to address your front shaft sooner than later and for the same reason. The rear will be fine on a 4-door.
Upvote 0
