Donny
In a sea of choices and opinions what are the baselines?
If you want your JK to get you through the Rubicon, Black Bear Pass, Moab, Dusy, and all the other cool trails available to us what is the minimum lift, tire size, armor (both under and body), and any other important items in your opinion.
I ask because I am starting(Have) to get BIG EYS! I love the thought of running a coilover system but is it NEEDED vs. a good 3"-4" coil lift?
Is it NEEDED to get my rig setup for 37-40" tires vs. 35's as an end state goal.
Do I NEED beadlock's or will a 8' wide alloy wheel be ok? (AND why doesn't the tire UNBEAD on the inside? you would think they would just make the outside the same way and save us some money:yup
Now then, there will be those that want to answer by saying "it depends on what kinda wheeling you want to do" I want to aggressively work towards doing the trails I mentioned above without over building. I'm NOT trying to be cheap just well informed. Just trying to create the right tool for the jobs ahead. If a $5 hammer will do the job well then why buy a $65 hammer with the kung fu grip?
Donny
Donny
