Scrambler
My 1997 Jeep Wrangler with a 4.0 is giving me fits and I can't figure out what the problem is. Let's start off with the symptoms: It has no power, sputters, and "backfires" from under the hood, not the exhaust. If I get it under enough load it will smooth out until I switch gears and then I have to go through this throttling dance again until I can get it under enough load to smooth out in the next gear.
Parts replaced: Crankshaft Position Sensor, Upstream 02 sensor, all spark plugs, distributor cap, rotary button, and the ignition pick up coil.
It has been hooked up to 2 different OBDII readers and the big ass machine that shows the electrical pulses, with no indications of a problem. At idle, this thing purrs like a kitten, but as soon as you want to drive it down the road it goes full retard. I'm stumped. If anyone has any suggestions on what I should replace next, I am all ears. By the way, I have already added the attenuater and put my last oil change's oil in the frame rails, so I know it isn't that. :cheesy:
