No it’s probably better to leave it on there so it bakes like clay and they you’ll have to use a jackhammer to get it off.
When you take a shit do you wipe your ass or look to correct the problem somewhere else first?
What do i do about the fluid leaking out
It does have power but when you turn the wheel fast it has a little resistanceYou could just carry a bottle of power steering fluid and when the level in the Jeep gets low enough, just refill it and you’ll always have fresh fluid.
Edit: does it even have power steering?!
That may be normal. How often did you try turning the wheel “fast” prior to having an issue? No offense but you could be over analyzing it. My 2017 JKU sometimes has resistance when turning, especially when aired down.
Well I didn't try many times before the issue but it seems to work fine. I just checked it and the fluid was really low
I located where the leak is it is up by where the box is where the fluid is held. What should I do
Anytime that you're in the mud you should clean everything as soon as you possibly can......is that not common knowledge? :thinking:
