The compressor is powerful, fills the tires rapidly, but the pressure dial is off by a few PSI I took 3 separate readings using different brands, and my tire pressure sensor, all within a pound of each other but the Tozalazz was more than 5 pounds off
I'm sold
The Kaeser M255 Air Compressor seems to offer more CFM (900 CFM) than the unit you recommended.The compressor is powerful, fills the tires rapidly, but the pressure dial is off by a few PSI I took 3 separate readings using different brands, and my tire pressure sensor, all within a pound of each other but the Tozalazz was more than 5 pounds off
Maybe in a trailer configuration?Thanks, I will eventually go with an on board air compressor.
