So I'm going the redneck ram route. Just curious because I've seen setups with the reservior and cooler. Is that required or what setup would require going that route? I'm currently on 37s and doubt I'll ever go higher than that.
Sent from my SM-G965U using Tapatalk
Reservoir yes. Cooler no.
A reservoir? The stock reservoir works.
Sure it works. I would rather have the PSC one though.
It definitely looks cool
I've got the PSC Big Bore kit. Cooler, reservoir, the whole hog and it works well. I had the original pump go out and they sent me a new one, works perfect. I saw someone was talking about a whine. My understanding is that is from a loose fitting. It can be loose enough to suck air under heavy load but not leak fluid. I had it, went through and tightened everything and no whine.
So... I'm a fan of the larger reservoir and cooler, more volume and cooler is better for this setup.
IMO
I think I'm going to go cooler for piece of mind and you're right, it's cheap. What's the difference with AN 6 or 8,which should I get? Any kits yall recommend or is psc the way to go?
So stock is 6 right? That's what I should go with?Different size, 6 is roughly 3/8” 8 is 1/2”. Bigger = more flow / holds more fluid. Depends on the rest of your system no point in using different sizes.
Perfect, thanksYou can get a dual pass Derale cooler cheaper on Summitt Racing or other sites. The ones on the PSC site are single pass only.
This is the dual pass I have: https://www.summitracing.com/parts/der-13260
Perfect, thanks
