Danger New member May 4, 2015 #1 We are having a hard time turning! PSC, 40 Nittos, Detroit. I know that is already tuff to steer, was just wondering if their some other things I should check.
ridg3runner - May 4, 2015 #2 Sounds like you may have something in a bind. I'm running the exact same setup, but with an ARB locker and I can turn with on finger on the wheel.
Danger New member May 4, 2015 #3 Everything looks normal, I'm wondering if pump is not working right. When you say turns on a dime, is that when your locked also.
Danger New member May 4, 2015 #8 It's has a dodge motor with factory pump. That's where I was thinking I might be having the problem. Everything was fine for the first few months.
2013rubirick Hooked May 4, 2015 #9 Dana Jones said: It's has a dodge motor with factory pump. That's where I was thinking I might be having the problem. Everything was fine for the first few months. Click to expand... Ya your pump might be going bad. Get the psc high flow pump and it should solve your problem.
Danger New member May 4, 2015 #10 I figured I would call them Monday , was just looking for some Imput . Thanks for the replies..
big dr New member May 4, 2015 #11 My guess would also be the pump. My steering used to do weird stuff prior to the hi flow pump,,, then,, all fixed with the pump. Good luck!:thumb:
Irish JK Caught the Bug May 4, 2015 #12 2013rubirick said: Ya your pump might be going bad. Get the psc high flow pump and it should solve your problem. Click to expand... Well I'd use the word solve loosely there.
