Does adding Hydro Assist increase or diminish the load put on your draglink. I would assiume because the steering is assisted at the Tie Rod that there would be less pressure on the Draglink. Any thoughts/experience with this?
But more load on the Drag link Bracket (if attached there).... correct?
Brain fart... already fixed it.
Ok. Yeah, you do need to have confidence in your track bar bracket if you ram mounts there. I welded a synergy bracket to my PR44 and then welded a couple to tabs to it for the PSC ram. It’s held up well so far. Couple of trips to Moab, Rubicon, Calico, Big Bear, etc etc.
Lol. One of the reasons I decided to go with the PSC bolt-on bracket.
