whytiptoe
Ok say you already have another gear set and diff. for the front and rear. How long would it take to change it out. Only thing you would have to do is pull tires, brakes, axels, cover, diff and pinion gear, then you would install the new set. You would not be swapping any parts everything is ready.
Also if you have done it once and have your spacers correct would you need to check your backlash and everything again.
It might sound weird but what I would like to do for LONG drives is to change to a smaller road tire and gear set to save on fuel. Pull a trailer with all the tools and extras I would need to go on the trails. Before I would go back out I would be changing over to the larger tires and gears that would associate with the tires.
Thanks in advance for any help.
