G'day guys, I come from Australia.
I seek some solution for my jeep lift program. I want to change the tire from stock 245 75 R17 to 285 70 R17 mt tire.
About this move, from my research, it may be cause some rubbing at some point, and it may be hit the fender when i off road. So I want to solve this potential risk.
I know upgrade some real lift kit with shock and coil will be the best choose. Unfortunately, 2 inch lift for my stock jeep will 0.5-1 inch higher than 2 inch. That will cause 2 problems. First, it will against the Australian law,:naw: I need do some engineer certification. Second, may be need add more part to re-correct some angles.
It is my first modify my jeep, I do not want to get too much trouble. I hope make it as easy as I can. I still want make sure my jk's all geometry in the design range. So many people tell me use spacer and extension may be the best choose for me in this stage.
So here is the question,
1. how thick coil spacer and how long shock extension combination will give me the under 2 inch lift and make sure my 285 70 R17 mt tire working no problem on road and off road? I won't disconnect sway bar at this modify phase.
2. do i need to add some bump stop extension too?
3. if I want to add a Smittybilt XRC M.O.D. full length front Bumper but no winch very soon, is the stock coil with spacer will down very little or very visibly? How many thick the front coil spacer should I set up?
PS, I already ordered a set of steel wheel, 17X8 offset +30, local shop only give me the offset +30. They say it can make sure 285 tire no rubbing issue. I want +6 or 0 offset, they dont do that because australian law dont allow the tire wilder than the fender. :naw:
