dchew
This post in Eddie and Cindy's Tahoe thread got me thinking about my setup:
http://wayalife.com/showthread.php?8844-Livin-the-Life-Tahoe-2013&p=143781&viewfull=1#post143781
Those coils are really cranked down for more lift compared to mine. I assume this was because they were loaded up for a month-long trip, not to mention RubiCat has an Evo carrier vs. my lightweight-but-not-recommended Teraflex tire carrier. For reference my JKUR weighs in at 5600 lbs with me, 1/2 tank of gas and the normal tools / recovery gear.
There may be enough bolt-on coilover's on this forum to show some variations. I'm curious how others are running??
Here is how I'm set up in the front. Sorry for the dirt![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![DChew_130721_1054.jpg DChew_130721_1054.jpg](https://www.wayalife.com/data/attachments/33/33266-d0bb932c90ef505d2e5dde760a8f966c.jpg)
![DChew_130721_1055.jpg DChew_130721_1055.jpg](https://www.wayalife.com/data/attachments/33/33273-6c98fdba9d56d48f1a0edb36bb61f2eb.jpg)
And in the back. Note I cut down my bumpstop extensions about 1" (probably too much).
![DChew_130721_1056.jpg DChew_130721_1056.jpg](https://www.wayalife.com/data/attachments/33/33276-b6caba088a82e8b46175ed8813c61d70.jpg)
![DChew_130721_1057.jpg DChew_130721_1057.jpg](https://www.wayalife.com/data/attachments/33/33285-3f045d0178970c22a3b5eefbf0764931.jpg)
I've got relatively little lift dialed in, with ~1" to the bumpstops, and a little less to the double nut rings that initiate the heavier spring. BTW I did not change my springs; are the standard EVO/King setup. I did add the AGM sliders, which means my double nut rings are higher than with King sliders. It is the distance from the top of the slider that matters. About 1/2-3/4" in my case.
I certainly use my bumpstops constantly with this setup. I also know EVO sometimes recommends reducing the pressure in the King bump stops, since JK's are relatively light. I haven't done that, and I think they are a bit harsh.
Dave
Dave
