Housing for factory fog lights
Sporadic
Does anyone know if there is an external housing available for the factory JK fog lights. I'm trying to figure out a way to reuse these on my new 1/4 pounder bumper.
Thanks,
Ty
:beer:
I've been looking into this as well. I'm considering going all EVO with the quarter pounder, sliders and rear bumper fascia with D ring mounts. I too want to keep the fog lights (I use them almost every morning here). This is what I have found in my research:
http://www.quadratec.com/products/12001_2117_07.htm
They bolt on, so I'm pretty sure holes would have to be drilled. I haven't been able to find a picture of how they mount yet. The only other option I have found is to purchase free standing fog lights and mount them t a fairlead mount. Hope this helps. These light pods are probably the route I will go if I get the quarter pounder.
I remember seeing somewhere, they used 4" pvc caps for housings and it actually looked pretty good.
Sent from the"Zone of Influence"
Those may actually work using the hi-lift holes.
EVO has a new light bracket for the 1/4 pounder so I wonder if these housings would work together allowing for a cleaner look?
Do you have a link for the EVO light mount for the 1/4 pounder? Can't find them anywhere
I would use the ABS caps before PVC. ABS is the black pipe used in plumbing for drain pipes.
R/
Will
The member krieger or kreiger on here bolted some D2's to the T in the front of the bumper. He just spaced it with a washer.
