My jeep just show hot oil warning for 4 second and it's gone..
What's wrong with it?
Do i have to check?
Maybe nothing? Maybe something? If it were me I'd give things a check.
Do i have to check?
just normal driving or while you are wheelin it???
andrew -
Just normal driving..
And the temp off engine was normal too.
get it checked! it could be the overfill of the oil, but i would have it looked at just in case!
andrew -
The hot oil light is a warning for your transmission fluid. Not engine oil.
yes, i thought that too... but it shouldnt light up while just regular driving. thought maybe too much oil might make it chime....
andrew -
Usually happens when you are climbing a steep grade and the transmission heats up. You could possibly have burnt your fluid. A fluid change would be a good idea. Just make sure they don't remove your fluid by sucking it out your filler tube. You can read about the hot oil light in your manual. When transmission fluid gets to hot it can boil out of your filler tube. This has been linked to engine fires.
