Ok that was easy, but now have a new problem. I took 1/4" off right turn stops and tested. Gained about an inch at full turn measuring from the the inside of the tire to the frame. Just about what I was hoping for. Great! So I did the same for the left turn stops. Had my wife get in the jeep and turn to measure and gained....nothing. The stops are not touching. WTF? So I unbolted steering stabilizer just in case. No still the same. So now I am scratching my head. I have synergy adjustable drag link flipped. 4" EVO springs which netted 4.5" lift. The adjuster is almost maxed out long but the pitman arm end is almost all the way in. So I am thinking if I adjust it shorter a full revolution of the steering wheel and re center will that set off the stability control? Only other way I can think is to re index the steering shaft. At full turn left the pitman arm is almost at the sway bar and very close to frame. Any ideas?
Sent from my iPad using
WAYALIFE mobile app
