Gibbo said:Is anyone using a high steer correction kit, i.e. front track bar bracket and a flip high steer drag link. It's suppose to raise roll center to reduce body roll. Just interested in some opinions.
Have the Synergy on mine but I don't know that it has a major difference in handling for me. I only have a 3" lift which is the minimum recommended so maybe that is the factor but I have a feeling that the springs I'm running are crap and that is what is really causing my handling woes.
I don't want to bash the company that made the springs until I get another set on to test so don't ask what I'm running but I've already changed the rest of the front end suspension and shocks all around without a satisfactory experience on road or off.
Back to the flip, I did find out how crucial it is that your drag link and track bar are parallel much more than that they are horizontal. If they aren't parallel the bump steer is ridiculous to the point of ESC freak out when you hit a bump.
the flip kit is well worth the money if your running over 3" of lift. It virtually eliminates bump steer, and gives the steering more of a stock feel. It's really important to have your draglink and track bar as close to parallel as possible.
My JK sits 5.5" above stock hight. tried bracket w/o drag link and naturally drove like crap so took it back off. I have got to get new wheels cause my AEV's are 5.75" back space and touch the drag link. Max back space with Synergy kit is 4.75. Sometimes one thing leads to another and another. Good thing I enjoy all of this. Thanks for everyone's input. I really like this site.:beer:as mentioned, this should be installed on a jeep with 3" of lift or more as it will correct your steering geometry. if you're sitting less than that, it is not needed and in some cases, will shift your axle off center.
Another thing that worried me was drilling out the steering knuckle to fit the adaptor, once that's done there's no going back. Cheers.
