Canvas JK - Mar 31, 2014 #1 Replacing front brake lines using the WAL sticky, however I am not sure I have the brake lines routed. Do I need to route it where the factory line was. At a stopping point. Please help!!!! R/ Will
wayoflife Administrator Staff member Mar 31, 2014 #2 Not sure I understand what the problem is? Looks okay to me :idontknow:
Canvas JK - Mar 31, 2014 #3 Factory brake line and wires are routed on the front side of the shock. Do indeed to remove the front shock lower bolt to reroute the wires? R/ Will
MTG Caught the Bug Mar 31, 2014 #4 Canvas JK said: Factory brake line and wires are routed on the front side of the shock. View attachment 76623 Do indeed to remove the front shock lower bolt to reroute the wires? R/ Will Click to expand... No, but is your ABS line still routed that way in the first picture? If so, I'd probably move it and zip tie it to your brake line. :yup:
Canvas JK - Mar 31, 2014 #5 I have not moved the ABS wires. That was my question was to leave it in the factory position or move it. You are saying reroute and zip tie to the brake line. Sent from my fRuit product using WAL
wayoflife Administrator Staff member Mar 31, 2014 #6 What MTG said, you want to zip tie the ABS line to the brake line.
Canvas JK - Mar 31, 2014 #7 That is what I thought but wanted to make sure. Learning everyday about the JK. Thank you Eddie and MTG. You guys rock! R/ Will Sent from my fRuit product using WAL
