Help!!!
LIBOY
I will be installing New KC Lights on the WIndshield. As I start to add my wires to the Battery, Do they make an accessory terminal that I can add to the battery so that I can add my extra accesories.
You have a lot of different options available to you. You can get a Daystar switch panel and just add new switches to it as you get more stuff or, you can install something like this...
I got one for each of my Jeeps and love it:
http://www.offroadengineering.com/product-multiplex-system.html
Re: Help
Wayalife
Tahnks for that, I was actually talking about teh battery terminal itself. I was thinking about putting the daystar panel in.
Wayalife
This comes with a block that you can attach to the battery and then everything to it.
Can you recommend anything else that would attach right to the battery, again was thinking about puttying the daystar panel inside the vehicle.
Contact the member gtony12 as he's got a good handle on things like this.
There is a write up on the forum it's power block and accessories. There are a few different types out and I put a few pictures of them.
Here's what I did to add for multiple power (+) (-) connections. If this helps.
