Here is my predicament.... I had 2.5" coils and went to 4wheel parts to have the teraflex speed bumpsfront and rear installed. They initially said that my 2.5" springs would work then called during the job to say they will not and they would put on another set of springs... they did and they are 4" springs.
Now...I do have adjustable front and rear Full traction track bars and straightened that part out.
1. I do not want my 2013 Jk 2dr Rubicon that high.
2. if I kept that height, I am looking at an expense that I do not need. ie; front and rear drive shafts, adjustable upper and lower control arms front and rear.
What I simply wanted was to put the fox 2.0 terraflex kit as well as the speedbumps, I want to keep the factory control arms.
My questions are this,
Will 3" coils work for this?
Are the 3" Evo Plush coils actual 3" on a 2DR?
Will I need control arms with the 3" coils to do the job right?
Do I need all 8 control arms?
Will I need rear drive shaft?
Will replacing the front drive shaft be the right decision for 3" lift?
Also, I am installing 35 / 1250 / R15 BFG KM2's next week. I will have 4.10 backspacing on my wheels.
. I did all the research and messuring before I made the decision to intall the Terraflex fox and Speedbump set up. from my measurements they would work but I was sold that they would not.
Any suggestions are very much appreciated and Helpful.
I do not want to dump another $2500 at this... I am looking at about $1000. Also need your suggestions on the sway bar links...should I get fixed front and new rear or simply use the stock rear on the front for 3".
I do know that the teraflex 2.5" springs are actually 3" on a 2DR.
Thank you for helping me with my Fubar!!!
Please help!!! I do not want to run too long with this in my head!! I am losing sleep over it!!
