reece_price
I would like some help trying to figure out a overheating issue on my JKUR. Background 100k miles 37s 5.13 gears automatic. Metal bumpers and full under belly skids.
So my Jeep stays mostly cool. I can cruise around drive highway up to 65 ish and it stays at around 223ish that's with AC on full blast. But if I start going above the 65ish 3k RPM range it starts to heat up. It's not immediate, but it's starts warming up. I just did a full coolant flush and it seems a little better, but still a problem. Using a scan tool I pushed it before the flush and temp got up to 238 before I let off the throttle, it then cooled back down to 220 while cruising at 60ish.
When the engine is cool I start it up and the temp climbs quickly like it should then it levels out around 220 at idle. Which tells me the thermostat is working. It is a replacement unit from auto parts store, old one stuck closed on me and had to replace it.
I can crawl around off road and it's fine. It's just the highway speed it does not like.
Any help would be appreciated. I'm debating gutting the whole coolant system and replacing it all because everything has 100K miles on it.
My ideas would be water-pump is worn and not moving coolant efficiently around, or thermostat is not opening fully.
