Help-EVO Double D long arm upgrade
Jkzinger
We are in the middle of installing the EVO Double D long arm upgrade and the front driver side bracket is in the way of the driver side catalytic converter. The exhaust won't go back on with the bracket installed. Did I get the wrong bracket? There is nothing in the instructions that I received that addresses this issue! They just said remove the exhaust and install bracket.
This is on a 2010 JKU Rubicon. Currently in pieces at my buddies house!
Any help would be appreciated!
Your going to need to cut the cat off and rotate it. Then reweld it
Nothing wrong with the bracket, 2010 has a slight exhaust change
