Hello from Olympia WA
jeffk487
Just retired added a 2023 red 2L Sahara Unlimited to my stable in transition from this state to sunshine in Az probably just outside Tucson by the end of summer. Have a quick question regarding diff and trans fluid and transfer case…I’ve watched vids that say you should plan on replacing existing bolts with new but that just sounds kinda crazy to me? Plus I checked mopar online it is $3.84 per hex nut…chances are I would never buy from them anyway after looking at other items…
Welcome to Wayalife from TX
I've yet to swap out the bolts from doing a fluid flush, did a transmission pan replacement on my 2018, reused the bolts.
Isn't transfer case lifetime fluid on those? Like not needing to be changed until like 150K or something?
Welcome to wayalife
Thank you I could not fathom the equipment under such considerable strain to necessitate this.
Welcome to Wayalife!
Unless you replace the differential cover with one that specifically comes with new hardware I’d say it’s not necessary to use new hardware.
