Hello from afar!
TJM
I've been a member here for a while, mostly just to look for info regarding my wife's Jeep. I'm currently in Afghanistan and will need a new vehicle when I get home and would really like to get a Wrangler. I was wondering where I would go, forum-wise, to look for advice. I have a budget and model in mind. Thanks!
Thanks!
Any other issues (especially mechanical) that I should know to avoid for certain years?
Apparently some early 12’s have a sand casting issue, but I haven’t had any issues with mine. I have heard about a lifter issue on some years but not too sure about anything else.
Welcome from Arizona! If you’re not set on a 4 door, that will greatly help your budget as will a manual transmission. I’d try to do a 13 or newer to get the 3.6 engine and avoid the possible sand casting issue. Also you get the newer dash. Stay safe over there. 👍
Welcome from SoCal
Thanks for your service 🇺🇸
Look for a 13 or better even if you have to stretch a bit to do it. It will save you headaches and $$ down the road
