Tranquillity
Hey guys, any of you happened to crack your hard top ? Can it be repaired ?
I'll try to take a picture tomorrow. It's stored but I can manage something. And it's cracked on the bottom corner.
Does the crack extend all the way to the weatherstripping and is it cracked all the way thru, or just the exterior?
Do you just want to fix it so that it is functional? Or, do you want it to look new?
Sand down, to remove and loose material.
Mix a 10:1 ratio of resin and chopped fiber.
Apply mixture to outer surface and allow sufficient time to cure.
Mix new batch of resin/chopped fiber 10:1 and apply to inner surface and allow for sufficient cure.
Block sand to match adjacent contour.
Prime and paint repair area.
Sent via Ku SATCOM using the WAYALIFE mobile app
Thanks a lot guys, I'll do this :rock:
