I’ve had my 12k badlands for years without a single hiccup. On my second cable for it now. It’s a little slower but I’ve never had a single issue with it. In fact my friends warn m8000 died trying to get someone out of a mud hole and mine did it no problem, not saying that it’s better just pointing out the rhetoric of warn will always work and never die is a bit on the optimistic side- unmaintained is unmaintained no matter what the brand. I’m sure this is not a popular opinion around this forum though. Between me and friends we’ve got 4 of them, one switched to synthetic, and have put them through paces all still going strong. FYI the 9000lb version sucks. If you get one mount the solenoid box somewhere under hood, the plastic fade and crack when exposed to sunlight. I’ve been happy with the $20 snatchblock as well but rarely use it.
Has anyone ever used or know about the winches at harbor freight? I can’t afford a good one for now but I do need something. Please let me know.
-JCW-
I have a harbor frieight winch. 8000lb. It does ok. If i had it to do over I would have saved 300 more $ and got a warn.
Sent from my SM-G920V using WAYALIFE mobile app
There are a number of folks in my local club who've gotten theirs at HF. A few have seen a fair amount of use. The group's pretty active on FB. If they were deplorable, I'm sure someone would be unwinding a spool over it . Mileage varies but if having a winch is important to you, and, the choice is HF or not having a winch at all...
My struggle is HF is under $300 and every warn I find is over $1,000.
-JCW-
-JCW-
The Badlands winches are popular because of price. They do work but have solenoid issues that most people bypass by using the wireless remote kit (that also adds a weird delay sometimes) and they are known to be slow. However, they are also known to work when needed.
If your price point is $300, there are several other mfg's that are supplying 9,500 lb winches in that price range including Smittybilt and even Warn has a fairly new budget line. The best I can tell they are basically all the same offshore winch with very few differences in stickers and remote designs.
You are the only one that knows your real budget. Just because someone else thinks that they needed to spend $1000 on a winch does not mean that you have to also. You also need to factor in how much you honestly plan on using it and what you will be using it for. Most people can get away easily with a $300 winch and never have an issue with it. If you buy a $300 winch and push it to it's limits and realize that you really do NEED something more, then sell the cheap winch and upgrade. With proper rigging and well thought out driving lines I doubt you will need the upgrade anytime soon.
I have personally seen plenty of China winches work just fine and without any issues BUT I have also seen my fair share of them fail when they really needed to work most. I cannot say the same about WARN.
This right here! and when I have seen Chinese winches fail, it is almost ALWAYS when the owner needed it to work the most. Nope, If there is 1 place to spend money on a jeep you wheel, it is recovery for sure. No matter how much money you could have "saved" Its all gone and then some when you cant get your jeep off the trail... :twocents:
You dont need a $1K warn, a VR series starts at only ~$500
