U should be able to as LEDs require a lot less current (wattage) vs halogen.
Ok, great. I thought so.
Is the only reason you need harnesses for the fog/head lights the canbus system?
Just got a bunch of LED offroad lights for Christmas and will be converting all my KC halogen lights to the new LED's. The LED's came alone without any kit. Just wondering if I'll be able to keep all my current routed wiring in place?
Are you installing an LED into the KC fixture or are you replacing the entire fixture with an LED?
Replacing all the KC's with Rigid Dually's and bars.
The existing wiring should be fine. The LEDs will likely draw much less power.
