teamahh
Hello all. Here's a bit of a background of what I have going on:
2008 Jeep JKUR on 35s
110k miles
Replaced all ball joints at around 95k miles
After purchasing the Jeep at around 90k miles, there was quite a bit I had to go through and learn. Like fixing the minor DW I had (replaced ball joints, new beefed track bar, upgraded bolts, welded washer = dw free) and finding out that the tires that came with this Jeep had a (edit: 'camber wear') problem..seeing that the tires are in their last season, I didn't really care much for them. But the cause of this is what I was trying to diagnose. So after I had replaced the crappy stock ball joints at 95k miles, and doing other things, I went and got alignment done. The tech who did the alignment had experience working on solid axles, so he seemed to know what he was looking at when he said my camber can't be set unless I get offset ball joints. Otherwise, the wear that happens on the tires will continue. This is after I had already put in new ball joints. I ignored it and went on with my driving and wheeling since it didn't really cause problems driving.
So here I am, a year later, looking to get new tires in the coming months. But am worried that the new tires will start cupping if I don't fix the core issue. I'm thinking that the core issue is a bent C since it hasn't had gussets welded to reinforce it.
My plan is to go get another alignment this Friday and see how far off my camber is from allowable. If it's within allowable then I'll just get the C gussets welded and reinforced and do more frequent rotations with the new tires. I think that will be liveable. But if the camber is too far off, is it a viable option to get offset ball joints? Replace the current (fairly new) ball joints. While doing that, weld up the C gussets to keep it from getting worse.
I seen a few different threads similar to this, but I wanted more opinions on what direction I should go.
Will post a few pics once I jump on a computer, not sure how to do this on my phone..
I am fairly new to a lot of this stuff and do read a lot of listings. But any advice/input/nickels are welcome!
110k miles
