linehand08
So I'll start of by telling what I've got and then we will get into where I want to go. It's a 2013 jku Rubicon with a 4.5 inch BDS long arm lift, Teraflex speed bumps front and back 4 inch up front 3 inch weld in's in the rear, 5.13 gears, Rcv axles in the dana 44s sitting on 37's, Genright roll cage, JE reel drivelines front and back 1310 front 1350 rear blah blah blah.
I am putting a Dana 60 up front and a 14 bolt in the rear using Artec's one ton kit also a Atlas transfer case.
Question's are do I go with 40s and 12 inch kings or 42s and 14 inch kings. It will have hydro assist steering also.
I'm leaning towards going with 42s but I fear I will have to change every thing to correct my suspension geometry. I don't want to put thousands of dollars towards suspension again so i'm thinking about rebel offroads coilover conversion on it and cutting sleeves into the links to lengthen them out for proper alignment of the axle.
So I guess i'm asking what do you guys think and what directions would you go ect.
