Gladiator Squeek in the rear
adrianmb1988
Hi everyone, I have a 2021 Gladiator and in California were starting to cool down to evening temps of id say 40 degrees give or take. In the morning I can hear a squeak coming from the rear passenger side. Is this just the rubber bushings? any ideas?
I had the same problem in the front on my 2021 JT Mojave. Turned out to be a shock, they replaced it under warranty last week.
I would let them check it out while it is under warranty.
Upvote 0
Recommend checking the upper rear sway bar mounts to ensure the are broken and if not, torque them to spec. A little silicone spray on the joints goes a long way. I usually squirt some of the upper rear spring perches as well after power washing my rig.
Upvote 0
