GIBSON HEADERS - CERAMIC COATED (07-11 WRANGLER JK)
Any one install or run these?
Any feedback or noticeable performance difference, benefits or challenges?
Sent from my iPhone using
WAYALIFE mobile app
I have a set i'll make you a deal.
but my experience on my 2010 3.8, I had them on for about a week and went back to stock. the ceramic coating didn't seem to do much to help with the heat.
My 3.8 wouldn't idle with them on, not sure if the ECU never adjusted for them or if they were just too hot and causing the plug to miss.
It did burn a couple of plug wires and instructions indicate having one of the wires custom made to angle away from the header tube (which I did but still ran rough)
by the time I installed enough heat shield to protect all the plastic and rubber under the hood if I needed to change plugs or other items around the headers I think it would've added a few extra hours of labor to remove the heat shielding and put it all back.
they put off a lot of heat, I could feel the heat coming out of the wheel well after parking and to open the hood required gloves - it was hot under there!
I've run headers on other engines with good results, but IMO the JK engine bay has no room to accommodate headers. I've look at and talked to guys with long tube headers , they seem to allow better room for the plugs but still put off a lot of heat. None could really determine if they got any better performance.
if you still want to try the Gibson's I'll make you a deal but no refunds no returns
I'm a lousy sales guy, i should've said they work great! good increase in low to mid-power, you can cook a 15lb turkey under the hood on the way to grandma's house, will make your engine feel better than new and you'll be attracting chicks up to a mile away!! :cheesy:
