JKEmmy
Hey everyone. So I have a 15 unlimited Sahara. So a Dana 30 up front. I have also regeared to 4.10s. I have never installed a locker so I had a shop install an ARB air locker for me. When I picked up the Jeep I asked what the backlash was and he said he took out the previous gears at .12 so he put it back at .12. Reading around, that sounds a little sloppy. I'm seeing .10 at the most. Not sure if it's different for the ARB or because I'm running 4.10s now. So is this a little loose? Should I adjust? And if I do will this change my gear pattern? Can I get away with just popping open the diff and adjusting those tension rollers on each side? Thanks guys.
