Gearbox Question
Kavanji
I have driven 2 different 2013 3.6 2door JKs this holiday and have noticed something that is puzzling me.
on the sahara in low range: If I select 1st gear and run it hard ( on the limiter) in the dunes it will not shift to 2nd unless I tell it to
on the rubicon in low range: If I select 1st gear and run it hard it will shift up to 2nd gear. this is very annoying as it breaks you speed up the slipface completely and most of the time results in you not making it and having to reverse down.
anyone know if it is a setting I can change or something the dealer can change in the ECU?
