USMC Wrangler
One of the biggest surprises of the day was after the gear swap. I started driving down the road and something didn’t feel right. I tried to manually shift my auto (‘13 JKUS) and nothing changed. I had programmed 4.56 in with my Flashpaq before I drove an inch. I had read of that issue of limp mode if it’s driven BEFORE programming.
I went back to my buddies and told them what was going on. Then I remembered counting the teeth on both ring and pinion gears to confirm a match. The rings had 41 teeth and the pinions 9. Dividing the two works out to 4.555555555555556. Again, I plugged 4.56 in the axle ratio change initially. I got the DTC of P0731 Gear 1 Incorrect Ratio.
The fix? Program in 4.55 instead of 4.56!
Maybe this has been covered here, but I couldn’t find it. I’m no engineer but it’s crazy to me that .01 difference could cause this. I also realize 4.88 is probably more common of a ratio. I do have to wonder if anyone else has experienced this and had to do something similar?
Overall "build thread"
http://wayalife.com/showthread.php?26097-I-guess-it-s-the-quot-Super-Stocker-quot-build
DIY trail/tube door build http://wayalife.com/showthread.php?24449-My-DIY-Doors
