mastrcruse
Complete Custom Dynatrac Pro Rock XD60-1550LT Series Front Axle Assembly - 2007-2017 Jeep JK
Custom Machined Dynatrac JK Pro Rock XD60-1550LT Series High Ground Clearance High Pinion (Reverse-cut) 35 Spline Heavy Duty Nodular Iron Front Axle Housing, Includes:
- Matched Housing Geometry, Pinion Angle, and Wheel Alignment for Lifted JK Suspension
- Axle Width 68.5"
- Heavy Duty Lightweight 3.75" Diameter x .25" Thick Wall DOM Axle Tubing, Installed
- Dynatrac Pro Rock XD60 1550-Series Forged Steel End Forgings, Installed
- Dynatrac Pro Rock XD60 Heavy Duty 3/16" Thick Fabricated JK Front Coil Spring Suspension Bracket Assembly Kit, Installed
- Dynatrac Pro Rock XD60 Heavy Duty Nodular Iron Powder Coated Diff Cover, O-ring Seal, 7/16" Diff Cover Bolts, Installed
- Axle is Detailed and Painted Dynatrac Gloss Black
Differential, Eaton ELocker4, D60, 4.56+, 35 Spline, 14023-010
Ring & Pinion, Super 60, 10.1" Ring Gear Diameter, 4.88 Ratio, Reverse-cut, Dana OEM 707475-4X
Ring & Pinion Set-up Kit, XD60 Front, D60 Carrier Bearings, Includes Dynatrac Exclusive XD60 Big Inner Pinion Bearing, Dana OEM, Installed
Input Yoke, 1350 U-Bolt Style, Dana OEM, Installed
U-Bolt Kit, 1350 Yoke, Included
Axle Shaft Kit, Pro Rock XD60-1550LT Series, 2007-2017 JK, 68.5" Width, Domestic 4340 Material, 35 Spline 1.5" Diameter, 10.40" Stubby Outers, Spicer 1550 U-Joints, with Boot Seals, Installed
Knuckle Kit, Dynatrac Pro Rock XD60 1550LT-Series, Aluminum, RH & LH, .620" Top-Down Tie Rod Taper & .620" Bottom-Up Drag Link Taper, Installed
Ball Joint Kit, Dynatrac 1550LT-Series, 2 Uppers and 2 Lowers
Dynatrac Pro Rock XD60-1550LT Series Front Wheel End Assembly Kit, 8 on 6.5", Installed, Includes:
- Dynatrac Heat-treated Chromoly Spindles
- Dynatrac Nodular Iron Wheel Hubs
- 8 on 6.5" Wheel Bolt Pattern with 9/16" Wheel Studs
- Serviceable D60 Timken Tapered Wheel Bearings
- Disc Brake Assembly Kit, Includes Dual Piston Calipers & 13.25" Diameter Vented Rotors
Dynatrac DynaLoc Heavy Duty 35 Spline Manual Locking Hub Assembly Kit, for Stub Hub Kit, Installed
JK ABS/Traction Control Retrofit, Front, Dynatrac XD60-1550LT Series, Installed
Tie Rod Assembly, JK Pro Rock XD60-1550LT Series, 68.5" Width, Included
Drag Link Adjustment Sleeve Assembly Kit, Drag Link, 2007-2017 JK, Included
85-140W GL-5 Gear Oil, Installed
- Axle Width 68.5"
