Front Swaybar Links Causing Frame Rubbing
JK_Dave
Wanted to get some feedback on my swaybar links that seem to be causing some serious rubbing issues against the frame. What's the general recommendation here? Should I replace these links with shorter ones to bring the swaybar more horizontal to the ground? Should I just grind down this spot on the frame and not worry about it?
The damage you see here was from a recent trip to Rausch Creek, not from daily driving.
View from the driver's side. Swaybar links measure out 12" post-to-post (identical length as the rears)
Close-up of the rubbing of the swaybar
Passenger side as well
Not sure there's a whole lot you can do other than grind down the tube a bit on both sides or install shorter links as you have mentioned. :thinking: On the other hand, the sway bar is doing a nice job of clearancing the frame on its own. :yup:
that's not uncommon after lifting Trim/grind it down just don't get into the weld and you're good to go.
