LarryG
So I installed my PR60s this week. Now that I have the Jeep back on tires, I measured the angle of the front and rear pinion and compared those angles to the angle of the transfer case output. On the rear, I assumed as I added a 3.5 lift that I would start by adding two turns to the Currie adjustable upper. These two turns were from the stock length original arm. It seems that was too much as my transfer case is at 92 degrees and the rear pinion angle is 86 degrees, meaning the rear pinion is angled upward compared to the transfer. I will take some turns out (shorten) the Currie, starting with the two I added.
On the front - the pinion angle is 79 degrees and the transfer case output is at 87 degrees. The transfer is aiming upward. I do not have adjustable control arms on the front, but even if I did, there is no way that I could pull the axle back far enough to offset the variance.
My questions are am I on track, here? Will the double cardan front drive shaft be the solution? Any experience on how many "turns" to bring the rear pinion angle to the sweet spot (it was a ROYAL P I T A getting the control arm to fit the first time and I am not looking forward to this adjustment).
Just a NOOB trying to build a Jeep!
