Front driveshaft angle 2007 jku
Hooligan
Is my drive shaft done? The boots not torn but the grease has obviously been coming out. How does the angle look ? 3" lift with stock arms and lca drop brackets.1390594035818.jpg
looks like it's slinging grease. start saving for a aftermarket one.should be ok for a while until it starts making noise.
agreed on the shaft. I just had this happen to me. drove with my boot torn for a couple of months, so you should be ok for a while.
When the grease starts to fly its time for a new one. The boot doesn't matter. Yes it will make it wear quicker but it's two different spots.
I started seeing grease slinging on mine and within a week it started to click. Being that it's the front you will be fine for now but be prepared for it to fail if you don't replace it. You need adjustable LCA's with the aftermarket shaft to set the pinion angle.
