jeeperstrudie
Hello everyone, I apologize if this is duplicated or somewhere else in the forum..... i've searched high/low and am struggling.... 2008 JKU, i've put teraflex alpine adjustable control arms on my jeep.
I'm on 4" teraflex springs and measure around 4" of lift. I wanted to re-center my front axle and get my pinion and caster back within spec. I've had the lower control arms in for about a month not realizing that I should have done the uppers first.
LCA's set at 23 3/8" with axle pretty close to centered on bumpstops.
UCA's D.S. at 19 1/4" P.S. Shorter (it's raining so I can't confirm right now)
I need to reconfirm my pinion angle but I believe i'm at 6.5 Deg currently (I'm assuming I'm shooting for 4.2 deg) so I'm sure I have more adjustment to do on the uppers.....
here is my dilemma / question:
1. When I went to put the P.S. UCA on, at 19 1/4" it was about 1/2" +/- off. Do I need to hold the 19 1/4" on both D.S. and P.S.?
2. what pinion angle should I be shooting for? I also struggle getting my angle finder to sit on top of the C due to grease fitting so i'm not confident on that reading.
