nmwranglerx
Changed out my front brakes today. Pretty much followed the write up for the rear brakes. I'd like a verification on the caliper bolt torque setting. These are two large (21 mm) bolts that I needed to loosen to get the caliper off. If I go by the handy project-jk torque settings list, I believe it's called the "front caliper adapter" and it should be torqued to 120 ft lbs. Since I was looking at the rear write up while working earlier today, I am currently only at 55 ft lbs leading me to believe I need to go back and tighten them further. Does this sound right? 55 fts lbs vs. 120 ft lbs seems like a big difference. As I recall, they were pretty hard to loosen up.
