JK's JK
Banned
EVO vs. Synergy Flip Kit
Hi Guys,
So I've owned the Jeep for a little over 6 months now and the first time driving long distance was the beginning of the week. I noticed when driving at freeway speeds going around corners my handling diminished and the handling became unstable. So I started to read a little on the issues with steering stability and how it should revert back to factory once you've reached over 3" of lift. So the three main parts that you have to worrie about is the trac bar, drag link and the tie rod. So I stared to read about the EVO flip kit and the Synergy flip kit. With the Flip kits it will bring the trac bar and the drag link flatter and then you can roll your tie rod to the top of the knuckle.
So I called and talked with a guy about the EVO setup and the Synergy setup. What was said is the EVO drag link uses a factory drag link setup and the Synergy uses a beefer drag link but accomplishes the same task. However the EVO compared to the Synergy is a difference in price.
My main question would be the difference between the two and would this fix the issue that I'm having?
Thank you guys.
Hi Guys,
Thank you guys.
