flush mount tail and reverse lights!
Jheapr
I'm about to ditch the factory tails on my TJ with some flush mounts. seems pretty straight forward, but i want to see some different options as far as light placement as well as any kind of suggestions on installation.
thanks for your help!
This may fair better in the TJ section if a mod could move it.
Cant you just drill a round hole tho and you can go flush mounts? If If you want something relatively flush, check out the maxxima lights which would also have a reverse light built in to them.
I am in the process of doing it myself to my tj. Just make sure when you drill the hole you cover up the 3 smaller holes. And I am measuring all angles to make sure they are both in the same spot
One of my factory lights was cracked so I installed the military led tail lights from Grote. Not perfectly flush, but another unique option.
attachment.php
