I think MTG knows how to fix this. It's common in cold weather.
Interesting you say that. Mine has only been doing it since overnight temps got down around freezing this year.
Mine does it too. Not a big enough deal yet to fix it
My washer fluid leaks when it gets cold too. I remember somebody a while back posed a thread about this issue and I believe they found it to be a seal on the pump that shrinks when it gets cold causing it to leak.
it's your washer fluid. you can buy washer fluid that has an antifreeze agent in it it won't harm anything.
I usually buy mine at a truck stop, it's cheap. it will sayn on-freezing on the bottle
Wait. You can actually buy washer fluid without an antifreeze agent in it? Wouldn't do much good in -30ºC.
Yup. Most of what they sell here in North Carolina is only good above 32 deg. Just have to make a conscious effort to read the label when buying.
Interesting. So, pretty much water with some coloring and maybe some soap for the bug-remover types.
